Bosch WFO2264GB/01 W/Machine
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFO2264GB/01 W/Machine
  • #34788
    mike412
    Hi Guys.
    Went to this machine today, Not Heating. Element OK, Thermistor 8k at ambient. Is this about right for the Thermistor?. If it is I guess we are looking at module problem. Had a look for dry joints but all looks ok.
    Any service info for this model gratefully received.
    Many Thanks in anticipation,
    Mike
    #244004
    gegsy
    Re: Bosch WFO2264GB/01 W/Machine
    NTC 8.5 – 10.6 Kohms equates to 10deg Celsius.
    NTC 5.4 – 6.5 Kohms equates to 20deg Celsius.
    Ambient temp is quoted from between 18 – 23deg Celsius.
    Even if no heat, the applaince will continue to wash in cold with no abortion of programme and will end as normal.
    Only the test prog will indicate any fault found with the NTC.
    HTH
    mike412
    Thanks Greg,
    Looks like this NTC is a tad high but points to Control module as I suspect. How do you get into the test prog on this model?.
    Many Thanks for your help,
    Mike
    #244006
    gegsy
    Will send you a little something for the weekend, sir 😯 😀
    mike412
    Thanks Greg.
    You really, really are my hero.
    Regards, Mike
    #244008
    gegsy
    Just glad to help, thats what its all about. We all get stuck somedays 😀
