Bosch WFO2465GB/01
  • #47859
    rocker
    This machine runs cont with 1 min left on led clock..have cleaned waste outlet / pressure system/ when first tested I removed the pressure tube from switch and time on led went to 0….re-checked pressure tube into drum for any obstruction none found..re-tested removed tube again this time made no difference..still on 1 minute..could it be a pressure switch fault or pcb.!! (ran on spin only 1 min showed on clock and this worked ok)
    can any bosch expert let me know. thanks John.
    #294825
    nomadPaul
    You could check the heater element going down to earth . Also , if i remember correctly , the NTC fitted with the heater , if faulty , can cause this spurious prob too.
    #294826
    rocker
    Re: Bosch WFO2465GB/01
    Cheers Paul. John
    #294827
    rocker
    Paul, the heater was damaged, though not enough to take out rcd but enough to cause this fault, as you correctly diagnosed. thanks John
    #294828
    rocker
    Fitted new heater, sadly same fault 1 min left..any advice please. John.
