Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFO2465GB/01 spin fault
- This topic has 6 replies, 4 voices, and was last updated 16 years, 9 months ago by
cornwell40.
July 8, 2009 at 11:07 pm #46921
cornwell40
ParticipantOriginal reported fault was clothes sopping wet, no spin, making clicking sound.
Tested machine on spin and got no motor action.Changed brushes (old ones just over half way down) and got motor action, albeit with noisy brushes. Masterpart pattern part.
Now when the machine starts to ramp into spin, the cold valve activates, at first pulses then as the spin gets up lets water in pretty constantly.
Not sure now whether this is the noisy brushes causing some corruption of the spin programme or the board is faulty and this was the original fault manifesting itself when the motor is turning again.
Anyone had this before. Going back with s/h board and gen brushes and will report back.TC
July 8, 2009 at 11:14 pm #291410Penguin45
ParticipantRe: Bosch WFO2465GB/01 sin fault
Electrical noise from the armature. Once they start, I doubt gen carbons will stop it. Had this a few times.
January 4, 2013 at 7:54 pm #291411Poppins
ParticipantRe: Bosch WFO2465GB/01 spin fault
TC
Did you ever cure this fault?
I have the same model showing the same symptoms whereby the cold water valve is opened when ramping up to spin. Was it the motor in the end?Cheers
ChrisJanuary 4, 2013 at 8:05 pm #291412Martin
Poppins wrote:Was it the motor in the end?
Motor’s are pretty easy to check out with an insulation tester. What readings do you get from it anyway?
January 4, 2013 at 8:58 pm #291413Poppins
Exactly, and the motor is testing ok and the whole machine is meggering ok. But i don’t understand why the cold valve is being triggered. I am suspecting that something is happening to the motor though and it is sending spurious signals to the PCB which is making it act odd or the PCB is duff of course. I changed the carbs using Bosch ones, which are a bit noisy, and tested the motor but didn’t have time for any more so I will be returning to it tomorrow to do a more thorough assessment
Never seen these particular symptoms before in any other Bosch or other make. My gut feeling though is its the motor.January 4, 2013 at 9:28 pm #291414Martin
Poppins wrote:My gut feeling though is its the motor.
I would tend to agree as it should not be noisy after the brushes are replaced. That suggests the com is knackered anyway. Also the PCB’s on these are susceptible to the fuzzy logic circuit failure due to the motor drawing too much current. A final thought to the valve being triggered is carbon dust build-up on the PCB?
January 13, 2013 at 10:25 pm #291415Poppins
For information
Replaced motor and all is well again 😀
