Bosch WFO2465GB/01 w/m
  • #14809
    mike412
    Good evening all.
    Anyone aware of any (less obvious) reasons why one of the above models wont take fab con through?.
    Mike.
    #160867
    Re: Bosch WFO2465GB/01 w/m
    The top section works on a cross over flow system – it gets blocked up. You can prick it out from below, or you may need to pull it apart – the roof insert can be pulled apart if it’s really bunged up.
    mike412
    Many thanks for your prompt reply Chris, I will probably order and fit a new top, it looks like they are as cheap as chips.
    Cheers,
    Mike.
    #160869
    gegsy
    Maybe oneof the solenoids of the dual valve could have failed also 😉
