Re: Bosch WFO2466GB/07
Have you checked to make sure that the selector switch hasn’t gone back into the PCB upside down ? IIRC , the slector on the board will always be set to the 12 o’clock position so if the selector was not at the ‘off’ position when you removed it , its possible that it could have gone on wrong.
If the selector switch is out by 180* , the first position it points to anti-clockwise , 30*C easy care ( 11 o’clock position ) will actually be the rinse programme.
Sorry if you’ve already thought of this 😉
