Bosch WFO2466GB/07 no heat
  • #66878
    robbra
    Replaced a duff element on this and it heated on test but after leaving customer put it on a hot wash and no heat. Seems like the board but I want to leave no stone unturned when I go back tomorrow. Could it be the thermister and what should it meter? Any other tests I can carry out?
    Rob
    #365507
    Re: Bosch WFO2466GB/07 no heat
    Heater relay probs on the board most likely Rob.
    #365508
    robbra
    Thanks Martin,
    is that a new board then or a repair?
    #365509
    robbra wrote:is that a new board then or a repair?
    Tough call that one Paul as it could just be burnt relay pins on the board. So inspection highly recommended I reckon. 😀
    #365510
    If you do a search for test + relay on here or on Google, it should come up with plenty of info. I found recently on an AEG board that burnt solder terminal is probably an indication that the internal contacts inside the relay are about to fail anyway so with any older machine I do that anyway.
    Mike.
