bosch WFO2467 GB/17 fill and spin fault
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries bosch WFO2467 GB/17 fill and spin fault
  • #56930
    Bosch auto WFO2467 GB /17
    select spin
    machine starts pumps timer starts to count down and drum revolves. after about a minute timer goes to 1 minute
    select rinse ans spin
    macine fills and turns normally ( have not run prog to end )
    select wash cotton 40 degrees
    machine starts to fill then stops and starts seems to be more eratic when motor starts but not sure. motor reverses ok
    tried disconnecting earth on heater and heater wires but no diff
    any ideas bosch geeks out there
    Re: bosch WFO2467 GB/17 fill and spin fault
    any thoughts ?
    #329307
    Allsorts
    Initial thoughts: Presuming that you have checked the motor brushes and they are fine, check to see if the motor comm is clogged with carbon .. and check the tacho
    #329308
    electrofix wrote:tried disconnecting earth on heater and heater wires but no diff
    Seems to me that the problem IS the heater. But I’m thinking that you must have meggered it anyway? Hmmmm? My reasoning being that if you disconnect the heater leads the machine would throw a wobbly anyway! Have you checked truly the heater? 😕
    #329309
    @ martin
    no have not megged it but will do and see what i get
    thanks
