would be really grateful if someone could tell me how to get into the diagnostics on this to retrieve any error code and test it
thanks for taking a look Ian
In the absence of such information (hunting for the Yetti in the foothills of the Himalayas much easier to achieve) may I enquire as to what the fault symptoms are?
Hi Martin
On the wash cycle the appliance will not complete the cycle, it continues to wash and wash with 1 on display .
If stopped it will do a rinse or spin and complete those cycles.
Insulation has been checked and the motor is just above 10 meg , could this be an issue ? i don’t know how low it should go before it causes problems , we don’t generally do bosch so experience is a bit limited
Thanks Ian
The motor insulation is poor and could be a problem. You didn’t mention the heater and that may be where the problem lies? Duff heater, or no feed to it, or module heater relay?
A tired and sticky pump rotor can also cause time-out (I.e 1min left on display). Likewise restricted drain system. Strip and clean motor to rid carbon dust should vastly improve megger reading anyway.
