this model has a time display. it does the cycles perfectly until final spin.
it begins the spin sequence at 12 minutes to go. every thing goes well until it gets to 5minutes at which point it jumps to 1 minute then stops dead.
this is either with or without a load in. checked the usual suspects , carbons, taken pipe off pressostat to ensure the empty position.
thing is this customer has two with the same problem and as this customer is the duke of northumberland, we get a lot of work from them and this is the first time ever that i’m stuck.
please advise of any remedy, or if they aren’t worth fixing then please let me know so that i can advise them.
cheers
keith
Can also take module with it aswell and do the same fault even when new motor fitted, making you doubt the diagnosis.
Be prepared on rare occasions to have to change both 😥
