Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFO2855GB/01 no spin.
- This topic has 7 replies, 7 voices, and was last updated 18 years, 7 months ago by
aqualectric.
September 3, 2007 at 9:54 pm #30262
aqualectric
ParticipantBosch WFO2855GB/01 washer. FD8305 701103.
Called to this machine for a ‘no spin’ fault: display showing 1 minute. Carbons worn to the limit, so I fitted new and tested the spin again. It will get to the low speed spin, display showing 10 minutes; then the spin is cut and the display shows 1 minute. 😕
I thought it could be the new carbons as they were a bit crackly at speed, so I cleaned the armature and tried again. Much better – now goes to second speed level – showing 6 minutes then the motor is ‘cut’ and display shows 1 minute. 👿
Will a failed armature cause this? The brushes fit well but they are still slightly crackly when the motor is accelerating. (all of the Bosch motors I’ve done before have been fine – even if they start out a bit noisy).Any ideas guys??
Steve.
September 3, 2007 at 11:06 pm #226554gegsy
ParticipantRe: Bosch WFO2855GB/01 no spin.
On rare occasions Ive had this and sometimes thoroughly cleaning the carbon dust from around motor has worked but usually its an irrepairable damged com thats at fault 😥
Only cure is a new motor 144616Model is WFO285SGB/01 😀
September 3, 2007 at 11:13 pm #226555Penguin45
I had one recently which despite cleaning everything and even “pre-bedding” the brushes with a fine file, lit up like a christmas tree at anything over 300 rpm and set the valves pulsing to boot. New motor 🙁 .
September 3, 2007 at 11:26 pm #226556aqualectric
Thanks, guys!!
I had a nasty feeling in my water that the motor was probably shot. :rolls:
Oh well – she’ll probably scrap it……… 👿Thanks again!!
Steve.
September 4, 2007 at 6:19 am #226557timdowning
See my post on the following date, it may help.
Wed Jun 06, 2007 7:01 pm
(Sorry don’t know how you link directly to it.)
[/list]
September 4, 2007 at 7:18 am #226558Martin
timdowning wrote:(Sorry don’t know how you link directly to it.)
You find the post in question Tim, highlight the URL in the address bar, then copy that address then paste it into your post. As below : –
http://www.ukwhitegoods.co.uk/modules.p … ht=#136765
HTH?
September 10, 2007 at 6:54 pm #226559keithos
I’ve had this fault a few times when fitting non gen carbons. Fitting genuine bosch carbons has always cured fault. Looking at old carbons will always tell you if armarure is faulty in motor, look for burned trailing edge. This works on all carbon brush motors & saves a lot of time cleaning faulty armatures. Bosch carbons are cut more accurately and is why the machine does not abort spin.
September 10, 2007 at 7:38 pm #226560Gordy29
i,ve had this fault run the machine on a 40c wash empty.
