Hi guys,
Got the above bosch washing machine that when you turn the dial to select a prog either nothing shows in the little display or just every line and dot is diplayed (8:88) and nothing happens other then the led moves from ready to the next relivant led (ie, wash or spin etc) but other then that nothing happens, but sometimes not even the leds light up.
Should i be thinking board fault?
Thanks in advance.
Ollie
I’ve replaced a couple of module boards due to this fault so you may be right? However, word of caution, make sure you’ve checked all other possible avenues first? Power supply in, wall socket etc…. 😉
