Bosch WFO2865UK/01 No final spin
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFO2865UK/01 No final spin
  • #66837
    Taff
    This machine with spin selected, drains, then goes through the distribute cycle with spin until the 6 minutes are remaining on the timer. It then switches to 1 minute, missing the full spin part of the cycle out. Motor brushes are new, pump out is fine, the level chamber is clear. Any pointers whould be appreciated.
    Regards
    Taff
    #365387
    Re: Bosch WFO2865UK/01 No final spin
    If there is any insulation probs on the motor it will cause the fuzzy logic in the PCB to abort. But more usually the symptoms point directly to the PCB being at fault….not a cheap fix. 😥
    #365388
    Wasn’t there something about heating elements or their connections cauing such faults on Bosch?
    Mike.
