Bosch WFP 3300 Eror Code F03
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFP 3300 Eror Code F03
  • #31303
    grantie
    Does anyone know what te above error code means please
    The machine is working normaill then gets thru to a certain part of the programme and the beeper goes and F03 flashes in red
    #230600
    nomadPaul
    Re: Bosch WFP 3300 Eror Code F03
    FO3 normally indicates a pumping out problem . I’d be checking your drain pump and fill/drain level pressure chamber on the rear of the drum . Power off if investigating . 😉
