BOSCH WFP 3300 FAULT CODE F01 Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › BOSCH WFP 3300 FAULT CODE F01 This topic has 4 replies, 3 voices, and was last updated 20 years ago by lightningbob. Viewing 5 posts - 1 through 5 (of 5 total) Author Posts March 31, 2006 at 6:26 pm #16821 lightningbobParticipant Hi, Just moved house, 1st use of our WFP 3300 produced fault code F01. Haven’t unpacked (ie. found) found the manual yet. Any ideas what could be wrong? Kind regards March 31, 2006 at 6:39 pm #171720 gegsyParticipant Re: BOSCH WFP 3300 FAULT CODE F01 Hi 1/ Check you have water coming out of hoses feeding appliance. 2/ Check you havent kinked the fill hose/s 3/ Check for low water pressure feeding appliance. Regards Greg March 31, 2006 at 7:01 pm #171721 linrewParticipant Re: BOSCH WFP 3300 FAULT CODE F01 hi fault code F01 means water intake greater than 4 mins, fault in aquastop as gegsy says check for water comming through the hose and make sure pressure is there (more than a dribble) if the machine seems to be filling ok it is possibly a blocked pressure chamber/hose linrew March 31, 2006 at 7:12 pm #171722 gegsyParticipant Re: BOSCH WFP 3300 FAULT CODE F01 linrew wrote: if the machine seems to be filling ok it is possibly a blocked pressure chamber/hose linrew Surely that would give you F03 ❓ 😀 Greg March 31, 2006 at 9:31 pm #171723 lightningbobParticipant Re: BOSCH WFP 3300 FAULT CODE F01 Thanks guys. I’ll check. Regards Author Posts Viewing 5 posts - 1 through 5 (of 5 total) You must be logged in to reply to this topic. Log In Username: Password: Keep me signed in Log In
