Bosch WFP 3300 Problem
  • #28330
    Pauly L
    Hi Guys,
    I have a Bosch WFP 3300 that has developed the following fault;
    Start a wash cycle, you hear the water filing but no visible signs in drum, 4 minutes later the machine displays the error code – F01.
    Have to remove the pump cover to drain out the water.
    Any ideas?
    Paul
    #217905
    gegsy
    Re: Bosch WFP 3300 Problem
    You must have low water pressure ,kinked fill hose or blocked strainers as computer board is timing out as fill is taking longer than 4 minutes.
    You should just be able to select drain or spin to empty water 😕
    Pauly L
    Hey Gegsy,
    Tried that, still no joy but realised that the problem seemed to be with hot water side – so selected 30 degrees rather than 40 and away she goes. Plenty of pressure on the hot water side and both filters (hose and cone filter in machine) are clear. Any ideas?
    Sincerely appreciate your help, mate
    Paul
    #217907
    gegsy
    I would then now check the HOT solenoid, with a multimeter, it should read app 2.5kOhms .
    Unplug appliance before attempting this :plug:
    Pauly L
    Cheers mate, will do
