Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch wfp3300
- This topic has 10 replies, 3 voices, and was last updated 14 years, 9 months ago by
RADDY59.
June 23, 2011 at 11:14 am #63548
RADDY59
ParticipantThis machine stops at the drain part of the cycle and is left full of water. If I drain the thing the water gushes out of the filter access hole like a river. Any ideas – I love this machine and I don’t want to lose it?
June 23, 2011 at 11:20 am #354094Martin
ParticipantRe: Bosch wfp3300
Pump impellor jammed with a button, coin, hairgrip…whatever maybe?
June 23, 2011 at 11:50 am #354095RADDY59
How do I get to that. the back of the machine? (the base has a plate I can’t get off – the back has some kind of weird headed bolts)
June 23, 2011 at 3:48 pm #354096Martin
RADDY59 wrote:How do I get to that.
From the front, directly behind the filter.
June 23, 2011 at 4:56 pm #354097RADDY59
Thanks for that. I took the 2 screws oof the base of the front. Do I need to take the rubber seal off the drum (scary……) because the front only moves forward a few inches?
June 23, 2011 at 7:34 pm #354098timdowning
I dont want to seem rude, but if you want to save your machine then I would call out an engineer it may be the safest bet. As it sounds like you may be undoing things you shouldn’t.
June 23, 2011 at 7:39 pm #354099Martin
….also I was suggesting you simply check the pump directly behind the filter cover and NOT taking the front panel off!
June 23, 2011 at 8:31 pm #354100RADDY59
Sorry Martin – you seemed to be implying I could remove said obstacle.
oh hum – now if I can just find a reliable engineer who will charge me less than a new machine in L37 😆
June 24, 2011 at 7:24 am #354101Martin
RADDY59 wrote:Sorry Martin – you seemed to be implying I could remove said obstacle.
Indeed I was, just remove round white drain filter and take a look inside pump/filter chamber to see if the 4 bladed pump impellor inside is not obstructed. No need to remove any screws, just peek inside, that’s all! 😉
June 24, 2011 at 9:34 am #354102RADDY59
I thought it the ‘impeller’ was a seperate box. Anyhow, just about to give it one last go this a.m., drained it all out (again), looked inside and saw what you meant – the fins – and there was the b*gger – a nail obviously from my little’uns collection!!If you were ’round here I’d take you for a pint – or two
many thanks
June 25, 2011 at 10:23 am #354103Martin
RADDY59 wrote:If you were ’round here I’d take you for a pint – or two
Just pop a crate of stout in the post to me, that’ll do! :clown:
