bosch WFP3300 error f03
  • #26390
    fjord_prefect
    is it time to junk this washing machine ????
    is now 6 years old, and over the years have had recurring F03 fault….
    engineers, and me cleaning all the gunk out of all the drain hoses etc, plus one pump replacement have cured the problem in the past….
    but now have intemittent f03 error …
    i have removed and cleaned all the hoses which has cured the problem for a few days before it returnned
    last week i could hear pump trying to click in but wasn’t pumping, and a quick tap of the drain pump would make it spring into life
    so….
    bought a new pump and installed it no problem…
    lo and behold , after 3 days trouble free the error has returned
    anybody got any idea what the issue is, other than the replacement pump being faulty too….. not likely really
    otherwise, i think it’s a miele with a ten year gaurantee
    #209947
    Re: bosch WFP3300 error f03
    fjord_prefect wrote:anybody got any idea what the issue is
    F03 indicates as a rule that the alloted drain period has elapsed. Usually it is a pump failure or a blocked (or partially blocked) drain out system? You say you have cleaned out all the hoses and replaced the pump, well now it’s best you just run a test to see how quickly the machine empties? In fact it should be less than 60 seconds and if it’s slower than that I guess you’ve got a button or something blocking the drain outlet somewhere and acting as a gate valve no doubt.
    The other thing you could check whilst your at it is the air chamber at the back of the tub. White clear plastic bottle above the motor, if that is gunged up you could get spurious error warnings like F03? 😉
    #209948
    Trilobite
    Could it be a sticky eco ball-valve in the sump (if fitted) causing such problems?
    #209949
    I thought Slartybartfast did the fjiords?
    Both posts above are valid – check the anti-syphon bottle in the rear left corner and the sink coupling (if appropriate) as well.
    fjord_prefect
    hey guys, and if any gals among you, you too
    thanks you all for your promt responses and advice, so
    it’s good friday and what better way to spend it than taking the bloody bosch apart again…….
    i will try all your suggestions and let you know the results anon
    regards
    Fjord (making planets is preferable to fixing washing machines) 🙂
    #209951
    fjord_prefect
    hi guys
    dare i say it or even mention it ……..
    it lives, it lives !!!!!!!!!!
    i removed and cleaned the eco-ball, though it looked ok
    it looks like the problem was the white clear plastic bottle above the motor.
    i wasn’t aware this could be removed and cleaned as it looked like part of the motor……..
    it was pretty solid, and the bottle was half full of water.
    anyways i removed all the gunge and hey presto…..no more F03… well not yet anyways
    so……….
    a big thanks to you all, a very happy fjord
