Bosch WFP3300 Problem – anyone help?
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFP3300 Problem – anyone help?
  • #25836
    pistolpete66
    > I have been having problems with my Bosch WFP3300 washing machine
    > purchased in April 2002 and used every day.
    > It was continually flashing up F03 error codes even though there was
    > nothing in the pump filter and the pump has recently been changed so
    > it can’t be that.
    > I then discovered the drain pipe was blocked with gunk – this was
    > cleared and the F03 stopped however, I now have a different problem:
    > The machine almost finishes the program wash, then starts again on
    > it’s own!
    > If I start program say 40 degree main wash with 1000 spin, the machine
    > goes right the way through, main, rinse, spin, then at around 6 or 7
    > minutes to go, jumps back to 101 minutes on the timer and starts
    > again, it then finishes as normal. It never did this prior to the F03
    > problems.
    > I also need advise regarding the drain hose situation as the pipe is
    > quite long and goes into the U bend arrangement of the sink rather
    > than a down pipe – the pipe goes up to the U bend not down so dirty
    > water may run back into the machine?
    > Is there a non return valve that can be easily fitted or do I need a
    > completely separate waste disposal system?
    > It’s been like that for some 5 years without problem up until now – my
    > dish washer is also connected to the sink U bend but this has a non
    > return valve fitted.
    > Help!
    #207773
    Re: Bosch WFP3300 Problem – anyone help?
    dish washer is also connected to the sink U bend but this has a non return valve fitted.
    I don’t think the waste pipe coupling or the way the drain hose fits to it would be a problem to leave as it is. What I think may well be the problem is that the drain hose from the pump to the sink will be blocked or partially blocked by something. After 5 years use I expect it to be solid with loads of ‘gunge’ anyway. 😉
    If the machine ‘times out’ during the draining process it will interrupt the microprocessor and lead it a merry dance, hence starting again, showing differing wash times etc…..
    If you need an engineer to sort it for you, then simply click on the link below 😉
    #207774
    gegsy
    The aqua sensors (if fitted) may have gunge around them also and then you would get erratic timing. (Part of its fuzzy logic)
    My suggestion would be to run a boil was with no clothes in the appliance, just detergent (not non bio or liquid)
    This hopefully will shift the crud. Try and do this procedure once a month to keep the appliance internally cleaner.
    pistolpete66
    Hi Guys,
    Many thanks for the replies – I have done as you have suggested but the problem remains, near the end of a wash cycle, the machine starts again. Maybe it’s just so full of gunge it’s confusing the sensors and it just needs a good service / clean. Other than that, the electronics are faulty.
    Next stage is an Engineer & I have already contacted a White Goods approved Company.
    Will post here how I get on….
    #207776
    pistolpete66
    Latest…
    One of your approved repairers came out, stripped the machine down and basically gave it a good clean however, the problem remains – when the machine gets near to finishing a wash cycle, it starts again but not from the beginning!
    Could it be the electronics have gone?
    I wll ask APG Basildon to come out again but just wondered if anyne had any ideas?
    The machine is clean, the pipes are unblocked and clear but something is still rotten in Denmark. Ho hum…
    #207777
    You didn’t mention if APG changed the pump? I guess they didn’t then?
    I wonder if you could just set your machine onto a rinse cycle, let it fill with water, stop it and then set it to spin. Set your stopwatch and time how quickly it drains away all the water? ( General guide: Normal water level = 45secs max, higher water level = 60 secs max) 😉
    #207778
    pistolpete66
    Hi Martin,
    APG didn’t change the pump but another repairer did back in August 06 when the machine first started displaying the F03 error code.
    The pump must still be OK. The machine is clean, the pipes are clear of blockages yet the damn thing still does not finish the wash cycle / program.
    There must be a reason it starts again from differing times?
    The High Water level button is not ever pressed so it can’t be that.
    It would be unusual if the Micro had gone wouldn’t it?
    #207779
    pistolpete66 wrote:It would be unusual if the Micro had gone wouldn’t it?
    Very unusual.
    Have you checked the drainout time yet?
    #207780
    pistolpete66
    Not yet as I am at work, will do so sometime over the weekend.
    #207781
    pistolpete66
    The machine continues to complete the wash program cycle down to about 7 mins then jumps back to 101 mins and starts the cycle form there.
    The approved repaired has said the front program selector board needs replacing and this is a code 480 and likely to be around 130.00 UK pounds just for the parts.
    I originally purchased a Bosch to last a long time but have spent a fortune on it so far not including the board that has yet to be fitted – wish I’d just purchased a new machine when it first went belly up.
    You live and learn.
