Bosch WFR 2860GB/01 wont start
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFR 2860GB/01 wont start
  • #15782
    Simon46
    Got a customer with one of these which wil not begin cycle. She complained that the start switch got stuck in then problems from there. When start pressed display disappears as if power failure then reappears. After removing/ refitting module the red start light now flashes. Machine knows the door is opened /closed. Error 1 was also seen on the display. Is this likely to be the module?
    Regards
    Simon
    #166308
    Re: Bosch WFR 2860GB/01 wont start
    Simon46 wrote:Is this likely to be the module?
    I pretty sure it is, usually caused in damp environments which affects the relay on the board. Often the display goes out too then comes back on without warning (the display module will be OK though). Door interlock locks as a result of a module fault.
    I’ve found sometimes warming the module area up a bit with a hairdryer makes it work fine (until it cools again 🙁 )
    #166309
    Simon46
    AS suspected. Thanks Martin.
    S.
    #166310
    Beever
    no it is unlikly that this fault is the pcb, this fault is a common fault, it is the analogue pressure switch (the black on not the brown one) Part no 182238
    regards
    Ian B
    #166311
    Simon46
    Maxx IT now In garage have seen it speaking German relays clicking and faint black blocks flashing on screen frquency twice a second.error 01. got it to flash a yellow startlight on easycare. More activity on easycare than on cottons but still will not start. I want this one for me.
    S.
    #166312
    Simon46
    Interesting did a Martin with hairdryer on main module machine now works http://www.ukwhitegoods.co.uk/modules.p … ght=wfr{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d}2A
    but on spin does distribute ramps to full spin and slows to stop. Repeated ad infinitum. Bereit was seen on this one as well.
    Will crack it
    S.
    #166313
    Probably motor on it’s way out then……. (Sorry).
    Beever wrote:this fault is a common fault, it is the analogue pressure switch
    An interesting diagnosis? I wonder why the pressure switch would cause the display to fail though?
    #166315
    Simon46
    Tony doesnt repair these modules either 🙁
    S.
    #166316
    Simon46
    Has anybody got a good 2nd hand module they want to part with?
    Regards
    Simon
    #166317
    Beever didn’t reply to my question over his Pressure switch diagnosis, but it might be a nice cheap easy option to try his theory out?
    #166318
    Simon46
    Still think module. when heat is applied to module PSU heatsink, appliance starts working bar spin speed ramp up too fast.
    S.
    #166319
    Simon46
    Too late. In moment of madness PCB on order 😆
    S.
    #166320
    keithwilliams
    don’t know if i should post this here but my nieghbour has got a 2801.
    i can’t get it to go and have suspected the module. here is the story.
    arrived to find machine with water in.
    tried to select a drain only and then a spin only. the on/off switch powered up the display but the start light flickered and had no effect. i subsequently checked the on/off swith its wiring to module, the door lock, the fhp motor, the drain pump. i also selected spin after removing the pressostat tube, still it would not activate the cycle.
    but if i select a wash cycle (any one) it will lock the door, the display acts as normal, it fills up to wash level then nothing, nada,zilch. after this i again try to select drain or spin and it’s back to not allowing the start button to function. pressure is on here as this guy is a neighbour. do you agree that it is the module?
    any advice will be much appreciated.
    thanks
    #166321
    Simon46
    Module fitted and configured. All o.k. Like the descriptions of everything it is doing like “fluffing up clothes”
    Very nice 😀 😀 😀
    S.
