Strange fault on this washing washer.. I turn the select dial to programe the door locks but machine is dead..but when I push the start button the door interlock releases.
any advive would be welcome as the pcb is expensive.
John
Does the display not fire up then? If not you may have to check that the connections are good to the power module. Display board (424675) is a bit on the pricey side. Ask customer if LCD has been starting to fade of late and difficult to read, might give a better clue? 😉
