Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › Bosch WFR2460GB/01 W/M
- This topic has 8 replies, 3 voices, and was last updated 17 years, 7 months ago by
mike412.
September 12, 2008 at 9:40 pm #39449
mike412
ParticipantHi folks.
One here for the experts out there…….
The fault is that on switching the machine to a programme the background of the display lights up but no infomation is displayed. If the machine is left in this state for about about half an hour the display comes on and the customer is then able to use as normal.
I suspect the control board, but this machine seems to have a more complex interlock than the norm.
Anyone got any ideas?.
Many Thanks in anticipation,
mikeSeptember 13, 2008 at 7:35 am #262458Martin
ParticipantRe: Bosch WFR2460GB/01 W/M
mike412 wrote:I suspect the control board,
I’d say more likely a faulty Display Module and easy to replace. But first check the ribbon connection into the main board as it may just be loose or slightly corroded and needs cleaning and pushing back in firmly. 😉
September 13, 2008 at 8:04 am #262459mike412
Thanks for that Martin. Will give it a Bash next week and post conclusion.
Cheers,
MikeSeptember 15, 2008 at 12:19 pm #262460Simon46
This isnt the bereit fault starting is it 😈 ?
S.
September 16, 2008 at 7:28 am #262461mike412
Hi.
I dont understand the last post but…
I have got this job booked for friday. Thinking about the problem, I am not sure that I made the fault completely clear in my 1st post.
The display “sort of” illuminates but does not dislay any info, and if you “start” the machine nothing happens. If you leave the machine in limbo for half an hour the display comes on , you can hit the start button and use the machine as normal. If it was a problem with the display board, would you not be immediately able to use the machine, but for lack of a display, not know exactly what it was doing?.Comments Welcome ,
Mike
September 16, 2008 at 7:45 am #262462Martin
Well as I mentioned earlier Mike, the display and its ribbon feeder are pretty easy to check out. The 30 minute delay scenario could indeed be more serious and mean the main module at fault?
The “Bereit” reference by Simon refers to some instances where the Display module defaults into German (Bereit = Ready) which it doesn’t in your case. 😉
The module itself may have been exposed to dampness and a quick blast with a hairdryer may be a solution? 😕
I had a similar model (same module) last week that was installed under a drainer board. Water had got into the module between the front fascia and the metal frame and onto the small connector blocks (brown wires) along the top of the module. In this instant the module was stuffed though 🙁
September 16, 2008 at 7:47 am #262463mike412
My word you are keen- didnt expect a reply from you until this evening!.
I will keep you posted.
Mike
September 17, 2008 at 6:46 am #262464Simon46
my display on my own WFR2860 started off blank then flickered when module warmed with hairdryer. Main module it ended up being. Not saying yours will be the same though.
http://www.ukwhitegoods.co.uk/modules.p … 41&start=0
S.
September 20, 2008 at 8:52 am #262465mike412
Didnt get a chance to take a second look at this as customer had decided to replace as the machine packed up completely so it would not even work after the half hour. Just as well ,it probably was the module stuffed.
Bit of a shame though, it was a nice looking machine.Thanks for all your help,
Mike.
