Bosch WFR2860gb/01 Blank display
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFR2860gb/01 Blank display
  • #13221
    Twoten
    Went to the above machine today; main display blank but backlight on, no LED’s on the option buttons, LED’s round selector switch work.
    Machine will not start.
    Machine kept in a garage.
    My money is on the control unit, can anyone confirm this beore I order a replacement at over £100?
    Thanks,
    Keith.
    #153651
    BSH-MAN
    Re: Bosch WFL2860gb/01 Blank display
    As long as no earth leak is found, I can’t think of any other reason but the module. 🙂
    #153652
    Twoten
    Thanks BSH-MAN I will order the PCB Monday,
    Keith.
    #153653
    Twoten
    Oops!
    It looks like the model number was wrong on this.
    It should have been WFR2860GB/01
    This machine has a separate LCD display to the control board. Has anyone come across this problem with this machine who can advise if it’s more likely to be the display or PCB or a 50/50 chance.
    I don’t fancy gambling on this one as the LCD retails at £88 and the PCB £150.
    #153654
    superfix
    Have changed quite a few display boards on these recently.
    However they have NEVER been completely blank, normally a few characters missing on display.
    #153655
    Got one just the same today, the machine sits in a cold ‘laundry room’ with a vented tumble dryer that isn’t vented and pumps loads of steam into the room!
    The display at the time I called was showing gibberish but after I lifted the lid and pointed a small hairdryer at the PCB and warmed it all up it worked fine 🙂
    Later in the day after it had cooled some the customer tried using it and its bu&&ered again 🙁 So I will order a new Main Board (401123) I guess as the Display Board I figure must be OK. (My logic being that if the Display Module were at fault you should still be able to set the machine into action. In this case nowt works, so it must be the more expensive option?)
    Hey ho!
