Re: Bosch WFR2866 Jumpy outer drum
gav425 wrote:Only makes the jumping when spin is starting could this be weak suspension legs?
As a rule the suspension legs (dampers) don’t give any trouble and last for years. Heavy or uneven loads will tend to make the drum jump around quite a lot though the machine should not move or be affected by this excess movement. It is important it stands on firm ground and the 4 adjusting feet are adjusted to compensate for any uneven floor and locked into position. The machine should also have clear gap of at least 1 cm around (front/back/top and sides)to allow for any vibration.
