Home › Forums › Trade Technical & Spare Parts Forums › Trade Technical Enquiries › BOSCH WFR2866GB/01???
- This topic has 11 replies, 3 voices, and was last updated 19 years ago by
S1MON.
March 14, 2007 at 5:42 pm #25843
S1MON
ParticipantWent too this m/c and it had no display present, power was getting there. When you close the door and turn the control knob nothing is lighting up and the door lock is not engaging.
I have replaced the main board and the display and it has had no difference at all. I have checked the usual things motor is fine etc…….. Wiring is ok. I have got voltage going to the module from the suppressor.
Any ideas im scratching my head here 😥
March 14, 2007 at 7:13 pm #207814timdowning
ParticipantRe: BOSCH WFR2866GB/01???
Are you sure the wiring connections haven’t been tampered with?
Have you tried a different wall socket?
March 14, 2007 at 7:16 pm #207815S1MON
yer tried two different sockets getting 240 at the supressor
March 14, 2007 at 7:24 pm #207816gegsy
Have you looked at the mains supressor 😕
March 14, 2007 at 7:27 pm #207817S1MON
yer ive check it it looks fine, in get 240v from there to the board
March 14, 2007 at 7:30 pm #207818gegsy
OK
You did check for cracks? don’t be fooled by 240v out of it, when push comes to shove there is no current when this faults, under load.
Will do a bit of lookin for you and report back 😀Greg
March 14, 2007 at 7:33 pm #207819S1MON
cheers, ill recheck…….
March 14, 2007 at 7:41 pm #207820gegsy
Ok Simon
If any component has a short circuit or earth fault, the display will either go dark or have no function.
Basically check components (heater first 😉 ) in turn,. replace as required.Greg
March 14, 2007 at 10:31 pm #207821S1MON
ok ill have a look tomorrow see what i come back with….
March 17, 2007 at 5:26 pm #207822S1MON
Got it sorted found the flow sensor was at fault. Tried the old board but that was coming up in German, configured the new one and now it is running great.
Cheers Gegsy
March 17, 2007 at 5:41 pm #207823gegsy
Excellent :tup:
March 17, 2007 at 7:17 pm #207824S1MON
