Bosch WFR3267GB/05 aborting wash
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFR3267GB/05 aborting wash
  • #58319
    nelson
    This is a strange one, I had the above machine in for a bearing replacement last week, delivered it back to the customer on Friday, gave it a quick fill and drain everything OK. The customer has used it a few times over the weekend but then yesterday the machine filled up a little bit and started to beep. Now this model has a LCD display, but the display on this machine does not work, and hasn’t done for over a year (without affecting the operation of the machine), I would assume that when the machine beeps it will probably display a fault code on the LCD display, so is there any other way to determine the fault code? Or has anybody any ideas what could be causing the machine to abort so early in the wash?
    Thanks for any help
    #334070
    timdowning
    Re: Bosch WFR3267GB/05 aborting wash
    Have you been back to see it yet?
    #334071
    nelson
    No, it’s a good old drive out (aren’t they always :rolls: ) so I was hoping to go armed with some ideas.
    #334072
    timdowning
    Well I’m thinking water supply problem. Its the sort of recall that makes me think the customer has kinked a hose. (I just wanted to check for leaks, you know that sort of thing, not that they will admit it!)
    Its always after this sort of job.
    #334073
    nelson
    Thanks Tim, I’ve asked the customer to pull the machine out and try it again, but it is still only filling a little bit then aborting. 🙁
    I am going to go out tomorrow and have a look :rolls:
    #334074
    nomadPaul
    How long between the fill and beeps ? If its 4 -5 mins , i’d be checking the valves . If it fills for approx 4-5 secs and then doesn’t do any more , sounds like the main wash valve is dodgy.
    #334075
    nationalhomecare
    Its got a flowmeter between the valve and soap dispenser, its probaly not picking up any impulses, it will beep after taking in the initial bit of water because it thinks the tap is closed but in truth its not, the display would be saying at this point ‘Tap Closed?’ these little things are crap, just bad luck that its gone I should think.
    Steve
