Bosch WFS4030 Control board
Home Forums Public Support Forums Spare Parts Help Bosch WFS4030 Control board
Viewing 15 posts - 1 through 15 (of 18 total)
  • #93497
    Unis4000
    Hi All
    Hope someone can help me!
    I have a Bosch WFS4030 which needs a new control board AKO 546 063/086
    Does anybody know where I can buy one?
    Is there anybody who repairs these?
    #454549
    Re: Bosch WFS4030 Control board
    Look up the part on Bosch’s own spare parts website (link below)
    http://www.bosch-home.co.uk/customer-se … pare-parts
    #454550
    Unis4000
    Hi Martin
    Already tried that – control board is not listed
    #454551
    Well I’ve just checked the site using that link and it’s all there, schematic diagrams, part no’s and all.
    OK, just give me the FULL ENr number if your machine. Do you want the control module that sits on the metal plate above the tub?
    #454552
    Agree with Martin.
    Where on your machine is this part ?
    What is your complete Enr number ?
    Why do you think this part is faulty as getting it wrong with Bosch can cost a bit
    Unis4000
    Apologies Martin you are right, found the diagram. I need the module that sits on the metal plate above the the tub part 00285737 costs £324.10
    Dave – The Enr number is WFS4030GB/07 the machine shows no lights, i traced the power from the mains lead, through the program selector switch to the board. Took the board out and there was signs of overheating underneath the relay. One of the connection to the coil was burnt and melted.
    Naresh
    #454554
    seems like bosch has no stock anyway so getting board may be hard
    post good pictures of both sides of the board and the damage
    let have a look at it and see if I or anyone can think of something
    there is poss this
    https://www.ebay.co.uk/itm/Bosch-Power- … 1393299315
    if the board has gone pop there is always the possibility it has also blown the other board.
    Unis4000
    Hi Dave
    Pictures…
    #454556
    thanks for pics
    cant see properly as pics are not good enough to be blown up to see. needs ones like on the ebay site
    not sure what that relay does but I am guessing heater, would need to see tracks and trace them.
    if it is just heater then board should work without it. I am guessing the round red unit may be a transformer top power the board. if the is not getting power or has blown board wont work especially if the tracks from the relay go to it
    that’s where I would start
    Unis4000
    Hi Dave
    I think you are right – i fixed a couple of tracks and installed the board with out the relay and managed to get some of the lights to work.
    Pressing the buttons switches the LED’s on and off.
    The spin speed LED’s are not lit and the start/stop button does not work.
    Will buy a new relay and install it tomorrow.
    Naresh
    #454558
    Unis4000
    Hi Dave
    Put a new relay in and still it does not work.
    Tried the link and contacted the shop – they may have sold the board.
    If i did get a new board – would it blow again – is there anything else that could cause the relay to overheat and damage the board?
    Regards
    Naresh
    #454559
    I would give the ebay shop a few days. they have a lot for sale (468 items) so I cant
    see them ignoring you
    one of the possibility’s here is the other board may have blown as well so spending lot of cash to find out your wrong would not be good. You have to decide if you want to take the chance
    have a real good look at all the tracks where it blew. use a magnifier and look for hairline cracks. its a long shot but that one is free
    Also that Bosch board ebay advert says its capital group retail in Harrow
    http://www.capitalrepairs.co.uk/
    could these be same people also in Harrow ?
    These control boards are built like brick outhouses. Solid and reliable to the nth degree. Hardly any point in messing with it until you can establish what caused it?
    Major suspect : The Motor
    #454561
    looking at the original pictures again
    The relay that has failed has burnt out on the coil connection which is nearly always bad news
    This looks like a change over relay so it may control the motor so Martin may be right on the motor problem
    you could check the motor but I think spending daft money on a board to see if it works may be silly
    Unis4000
    Okay so the prime suspect is the motor.
    How can I test to confirm that it is the motor?
    What do i look for?
    I have a digital avo meter.
    Regards
    Naresh
