BOSCH — WFS4030 gb/02
  • #25961
    brett1611
    Hi — I’ve not seen this machine before so any help would be nice. It works with the door open and you can select a program and the start light and door open light come on.
    But when you close the door all lights go out except the 900 spin option light which flashes. It then spins for a few seconds and stops completely. The selector knob moves on but to nowhere the same twice??
    ANY IDEAS brett 😕
    #208266
    Re: BOSCH — WFS4030 gb/02
    It is quite normal for these machines to operate with the door open, that is NOT a fault! (Whilst you can set any programme and it will advance through, the only thing it will do it pump then switch off with the door open!)
    What is the fault is the 900 LED flashing and that (I think?) relates to a motor fault (i.e Tacho or brushes – usually brushes). Strip and cleaning the motor, replacing the brushes and insuring the insulation reading is OK the likely cure? 😉
