Bosch WFT 2800/GB13 Washer Dryer no motor
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFT 2800/GB13 Washer Dryer no motor
  • #74517
    nasher55
    From my last post a long time ago I’m now a dab hand at replacing brushes, in fact a bit of a whizz……
    But replaced brushes last week – usual suspect one brush worn right down, other one halfway. Machine worked fine but 7 days later same again making all the right clicks but drum not turning.
    Any ideas? :rolls:
    #391880
    Re: Bosch WFT 2800/GB13 Washer Dryer no motor
    Did you fit those cheap and nasty ‘carbon brushes with tails’ I wonder?
    #391881
    nasher55
    Errr yes, because I cant see how i could make anything else fit? The ones with springs on the wires wouldnt do the job because the springs would get in the way and theres the two spiral springs built into the Brush mounting plate? So yes its the tails with clips.
    Just taken it to bits and reassembled, commutator was very carboned up but still doesn’t work after reassembly, I’m now suspecting the contacts into the windings block because I’ve had trouble with that before!
    #391882
    Or the embedded TOC in the brush ring has blown? Those brushes are crap and overheating has caused the problem I reckon. Proper job would be to replace the motor end housing but that costs 10 times the price. But even with spare parts you only get what you pay for. 😉
    #391883
    nasher55
    Sorry – the TOC? is that a capacitor? Could I just retain the end casting and replace the brush holder unit itself? Thanks for the help by the way.
    The machine appears to be ok again after reassembly this time, must have bent a contact out of alignment – they seem so flimsy for the job?
    #391884
    nasher55 wrote:Sorry – the TOC? is that a capacitor?
    No, thermal overload cut-out
    nasher55 wrote:Could I just retain the end casting and replace the brush holder unit itself?
    No, the whole end housing includes a new style brush ring unit (see HERE)
