Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch wft 2800 Will wash at 60 but not 40.
- This topic has 9 replies, 4 voices, and was last updated 17 years, 8 months ago by
Carm2.
August 7, 2008 at 12:52 pm #38593
Carm2
ParticipantBosch wft 2800
The washing machine in my house wont wash when set to 40 degrees, it will wash at 60 though.
Anyone know what could be wrong with it?
🙁August 7, 2008 at 5:58 pm #259365Turbo
ParticipantRe: Bosch wft 2800 Will wash at 60 but not 40.
Cold water valve maybe 😕
In what way does it not wash at 40?
Power Off Before Taking A Look.
GrahamAugust 7, 2008 at 8:53 pm #259366Carm2
When set to 40, It wont start the wash.
August 7, 2008 at 10:51 pm #259367Penguin45
60c – hot fill for wash.
40c – cold fill for wash.
No start on 40c – waiting for cold water……….Penguin45.
August 7, 2008 at 11:07 pm #259368Carm2
Thanks for the replies. 😀
So its the cold water valve you think?August 7, 2008 at 11:17 pm #259369Penguin45
Assuming that the water is turned on and that the fill hose is not kinked or trapped, cold water valve more or less has to the culprit. It’s this one HERE. Not the cheapest water valve ever made, so check the other points first.
Power off if you intend to do this yourself.
August 7, 2008 at 11:29 pm #259370gegsy
Also worth checking the sieve filters in the valve for silt blockage etc .
August 8, 2008 at 4:53 pm #259371Carm2
Update.
It starts washing at 40 but doesnt finish and skips to rinse or spin.not sure yet.
Ill be more specific when I find out more.
update
Thats what it used to do, now it doesnt start at all as I posted originally :rolls:August 25, 2008 at 1:40 pm #259372Carm2
How come it rinses with cold water?
Cold water is getting in somehow.
Does it not use the cold water valve?
Also whereabouts is the cold water valve located inside the machine,Is it hard to get to etc.
Ill look at the part and match it inside, but wondering if its hidden a bit.
Thanks🙂
August 25, 2008 at 11:48 pm #259373Penguin45
Please call your local engineer and get professional help. The thread is going nowhere.
Penguin45,
Moderator. -
