bosch wft 2806jb
  • #57130
    msappliance
    hi there this washer dryer will not heat on dry, im only getting live at the element, would this be caused by the ntc on the front of the element chamber?
    thank you
    #329933
    Re: bosch wft 2806jb
    msappliance wrote:would this be caused by the ntc on the front of the element chamber?
    Yes! Provided you’re certain the element is OK and that it’s not just a case of resetting the TOC and clearing a fluff blocked condenser. I’ve fitted a few NTC’s (175369) to cure the exact symptoms you describe.:wink:
    Do let us know how you get on. 😀
    P.S By the way the model number should read: WFT2806GB/13 (That should help anyone wanting to use the search facility at any stage in future.) 8)
    #329934
    msappliance
    hi, yes i check all that im gonna order part and let you know, cheers.
