Bosch WFT280 on fire.
  • #16631
    Only six years old washer dryer. 😥
    WFT2800GB/13
    FD 8009 00070
    Main motor burn out has set fire to the plastic water shed.
    A quick visual check of the electronics does not show any obvious damage, however due to the extortionate price of the motor on these I wonder what is the possibility that the modules have suffered damage as well?
    #170814
    gegsy
    Re: Bosch WFT280 on fire.
    Hi Jim
    Have a look at this http://www.ukwhitegoods.co.uk/modules.php?name=Forums&file=viewtopic&p=76386#76386
    Bryan
    Greg , don`t you find 95{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} of the time when a motor suffers severe damage it is obviously a bit of a risk but if there is no visual signs of damage to the module as in Jim`s case it`s worth the risk of fitting a new motor.
    On that other thread , motor seems to run ok apart from fast speed spin. I generally find if module has been damaged by motor fault then it results in no motor action when new motor fitted. I was going to tell him to check he hasn`t selected a slow spin speed.
    No definite answer Jim but if module physically looks ok , I`d be tempted to try new motor.
    Bryan
    #170816
    gegsy
    Read it again Bryan, a quarter of the commutator on the motor was destroyed. He fitted new motor and discovered slow spin speed.
    gegsy
    Also not always no motor action indicates module damage. Some Bosch machines can cause uncontrolled spin up and down.
    Regards
    Bryan
    Yeah , fair enough and if boro and yourself agree then I`m sure you`re right.
    What about Jim`s scenario then ❓ worth risking a motor or not.
    Bryan
    #170819
    Thanks for replies, I think that this customer would not feel safe with a repair on this machine in any event. The thing is, if they want a washer dryer, what do you recommend when a six year old Bosch goes up in smoke 😥
    #170820
    Triac might be knocked out, but it’s listed as a spare (155272), so repair of the power board is obviously an acceptable corse of action.
    gegsy
    iadom wrote:Thanks for replies, I think that this customer would not feel safe with a repair on this machine in any event. The thing is, if they want a washer dryer, what do you recommend when a six year old Bosch goes up in smoke 😥
    Hi Jim
    Thats a tuffy 😕 Its definately an isolated case. I take it appliance was in outside shed? Dampness must have been a factor if that were the case.
    Point that out to the customer, most modern machines do not appreciate such conditions and Bosch are no exception.
    PS – Bryan Im not always right 😆
    #170822
    Bryan
    Mike T will be hopeing you are if he forks out £200 on that module :lol:.
    Bryan
    #170823
    gegsy wrote:
    Hi Jim
    No, inside in a modern purpose built washroom, warm, dry, tiled floor. middle aged couple, no kids, no signs of leaks on the machine whatsoever.
    #170824
    gegsy
    Bryan
    Im 99.9{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure on that one Bryan 😉
    gegsy
    I would so say isolated incident and very rare. Convincing customer to buy another bosch, your on yer own there Jim 😆
    Which bit of “replace the triac” if it wont run the motor did you all miss? 😀 😀
