Bosch WFT2800/13 motor not operating
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFT2800/13 motor not operating
  • #31531
    Pim
    My Bosh WFT2800/13 washer dryer motor has stopped turning for both spin and washing. No noises and no attempts to move. Front panel display indicates normal features, drum can fill and drain ok. Is it possible to localise fault to say motor or pcb module – have multimeter and mains voltage tester available – at least some mains voltage seems to be in the bundle of wires going to the motor?
    Many thanks
    #231578
    Del
    Re: Bosch WFT2800/13 motor not operating
    Most likely the carbon brushes
    Have a look here:
    http://shop.ukwhitegoods.co.uk/index.ph … 24_600_664
    Remember plug out, power off
    Del
    #231579
    Pim
    Hi Del,
    Many thanks for the suggestion. Doesn’t look like the brushes, seem to have wear left and resistance between brushes is circa 2ohms for all commutator segments.
    Your next suggestion appreciated, many thanks
