Bosch WFT2800
  • #42817
    johnnyj
    Hello i,ve just been to a Bosch wft2800 stopped mid programe, i checked the brushes found them just about done, so i’ve changed motor end frame all seemed well, but got recalled started doing the same, i think it may be the pump as it seems to stick at end of wash and rinses intermitantly, there is a bit of play on the impellor, if the pump doesnt start does the module pick it up and halt the programe, i’d be grateful for any help cheers JJ
    #275013
    Re: Bosch WFT2800
    johnnyj wrote:if the pump doesnt start does the module pick it up and halt the programe,
    Indeed so, times out and throws a wobbly it does. Any side play in the impellor at all and pump should best be changed. 😉
    #275014
    johnnyj
    Re: Bosch WFT2800
    Thanks Martin i’ll pop back and put a pump in cheers. JJ
