Bosch WFT2800 code 3???
  • #78250
    WFT2800GB/13
    Oldish washer dryer, says dryer hasn’t worked for a while but the TOC just needed resetting.
    As often happens I could not replicate the supposed fault on visit. Motor fine ( fitted new about three years ago). Fills, drains, heats,washes,spins, meggers out fine.
    She said that it starts to wash then after less than 10 minutes it stops with 3 displayed in the small dryer time countdown window. ❓
    Any thoughts?
    Re: Bosch WFT2800 code 3???
    Off the back on my grey matter I think it means the hot valve is faulty? (I will look it up later when I get a moment and get back to you.)
    #404989
    Will await with baited breath. 😀
    #404990
    Just checked my customer database and confirmed my grey matter still clinging on to odd bits of info. August 2007 replaced hot valve to solve error code 3 on a WFT2800.
    Other error code 3’s (but only on WFK series m/s’s though) refer to knackered pumps.
    #404991
    Thanks Martin, will see how it goes, pump did sound a bit weary but was emptying fine and shouldn’t kick in at the start of a wash cycle anyway.
