Inherited this model whenever bought the house 5 years ago, and don’t have instruction manual. Visited Bosch support but the model number didn’t return any matches.
Machine has started to leak from the base. I’ve taken off the lower panel and there is clearly the filter access. The filter turns about 30 degrees but does not come out. I guess question is how far should the filter twist and how hard should I pull it to get it out? And at what point should I start to unscrew things to access the filter assembly?
My suspicion is that the leak and the stuck filter could be related ….
