Home › Forums › Public Support Forums › Help And Support › Washing Machine Help Forum › Bosch WFT2800 keeps on filling!
- This topic has 7 replies, 3 voices, and was last updated 18 years, 10 months ago by
shinyredheart.
May 28, 2007 at 11:08 am #27688
shinyredheart
ParticipantHi there
I have a Bosch WFT2800 washer dryer which is about 9 years old. I recently had the pump replaced and now I have another problem. When it comes to the end of a wash, instead of spinning and turning itself off, it keeps filling with water – to the extent that I had to turn off the water in order to stop it as it was leaking out of the drum. (Turning the power off had no effect.)
If I then turn it off and wait a while, it can be restarted on a spin cycle and it then performs normally. This has also happened when I’ve tried to use the dryer cycle – starts off drying fine but then fills with water (but not to the extent of flooding).
Can anyone give me some idea of what is wrong, and whether it would be economic to fix it, or cut my losses and go for a new one now?
Many thanks
May 28, 2007 at 11:17 am #215204gegsy
ParticipantRe: Bosch WFT2800 keeps on filling!
Does your model end with – GB/01,11,12 or 13 ?
The fault you describe sounds like one of the fill valves isn’t fully closing and will need replacing.
Unless you can isolate which, you may have to change both.Greg
May 28, 2007 at 11:39 am #215205shinyredheart
Thanks for such a quick reply – it ends with GB/01.
DebbieMay 28, 2007 at 3:41 pm #215206gegsy
The hot valve is 154645 @ £17.86 +VAT etc
The cold is more intensive as it has numerous valves, p/no 261841 @ £62.86 + VAT etc. Spares are available from spares@ukwhitegoods.co.uk if required 😀Un plug appliance if you are to investigate yourself :plug:
May 29, 2007 at 10:24 am #215207shinyredheart
Hi again
It’s definitely the cold valve. Is it easy enough to fit, or should I get a professional to do it?
Many thanks
May 29, 2007 at 10:50 am #215208Goatboy
shinyredheart wrote:Is it easy enough to fit, or should I get a professional to do it?
How long is a piece of string?
Hmmmmmmmmmmm!
If this was a Hayne’s manual, I’d give it 3 spanners 8)
Of course, unplug the appliance first!
June 4, 2007 at 12:47 pm #215209shinyredheart
Can I just say a huge thank you for the expert replies. Got the part from you on Friday, fitted in Saturday, machine good as new. Great stuff!
June 4, 2007 at 12:49 pm #215210gegsy
Glad to hear it :tup: well done 😉Greg
