Bosch WFT2800 overheat stat problem
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFT2800 overheat stat problem
  • #20956
    Twoten
    About a year ago the above machine overheat limiter went O/C. This was reset and has been OK since.
    Two weeks ago it tripped again so I checked the machine and reset. It has only lasted another 2 weeks being used twice and gone again.
    The fan appears to run OK, the cold valve into the condenser seems OK.
    I have run the dryer and made sure the NTC sensor cuts the heater outer when it gets hot and doesn’t trip out the limiter.
    I suspect it may be the NTC sensor only because I’m running out of ideas.
    Does anyone have any other suggestions .
    Thanks,
    Keith.
    #188907
    Re: Bosch WFT2800 overheat stat problem
    Twoten wrote:I suspect it may be the NTC sensor only because I’m running out of ideas.
    Did you clear out all the fluff from the condenser and bottom hose Keith?
    #188908
    Twoten
    Yes, removed the hose from the tub and had a clean out, it wasn’t too bad.
    #188909
    superfix
    Whole condenser needs to be removed and either cleaned (with hosepipe) or replaced.
    This will cure the problem 😉
    #188910
    Twoten
    I will take another look at the condenser,
    thanks,
    Keith.
