Our 8 year old unit has suddenly stopped spinning, still hear the relay clicking in and out. From what I’ve seen on this forum this seems a common problem solved by replacing the brushes, is this correct?
If so how easy is it to remove the motor and replace them, is there a mickey mouse photo showing how to remove the motor.
Recently replaced the drain pump, the most difficult part of the job was understanding and gaining access to the pump. I suspect this problem will be very similar…
Cheers for any help, near to splashing out £500….how long will the brushes take to arrive ? ? ?
