Bosch WFT2800 Wets Clothes as it “Dries”!
Home Forums Public Support Forums Help And Support Washing Machine Help Forum Bosch WFT2800 Wets Clothes as it “Dries”!
Viewing 1 post (of 1 total)
  • #15336
    Bosch Bish
    I have a Bosch WFT2800 (washer/dryer) that no longer dries. The clothes come out wetter than when they went in. The condenser’s not blocked and nor are any pips but I’m thinking it may be the drain pump not shifting enough water before water is re-sprayed into the condenser. Anyone have any ideas? The washer seems to crash quite frequently with error code 1 (drain pipe / suds pump) so this may be related. If I purge the drum (wash code 7) then the drain pump seems to be working fine but I can’t think of anything else. Please help!
    If it is the drain pump, how do you replace it??
    TIA
    John
