Bosch WFT2800GB/13
  • #13414
    Bryan
    Looking for motor end frame and BSH list it as 096805.
    Connect don`t have stock and Masterpart list it along with a few others but you can`t actually order this part no. it just keeps cross referencing to an alternative 😕
    Does anyone know if this part is interchangable with any of the others ❓
    Bryan
    #154765
    Re: Bosch WFT2800GB/13
    096331 Motor End Frame is the part no you need Bryan to fit that machine 😉
    #154766
    Bryan
    Thanks for that Martin and I don`t mean to doubt you but I make it 096805 . Has this changed to 096331 or are you 100{e5d1b7155a01ef1f3b9c9968eaba33524ee81600d00d4be2b4d93ac2e58cec2d} sure they are equivalent.
    Bryan
    #154767
    Dave_Conway
    Yes, both the same part Bryan 🙂
    Bryan
    Sorry to bring this up again but I`m in the process of replacing the end cap on this motor and whilst new one will fit (096331) I`m very concerned that the tacho is a different set up.
    On the original end cap the tacho is a 3 terminal device connected at 6 , 7 and 8 on the terminal block but with no resistance readings 😕 and as you know 096331 has 14 odd ohms between terminals 6 and 7.
    Any further thoughts appreciated but I think I`ll be getting my soldering iron out swapping brushes and toc.
    Bryan
    #154769
    At the top we have 088421 (no tacho coil) and below that of the 096331 which has a tacho coil fitted in the bottom! Which one do you have there Bryan??
    #154770
    Bryan
    Yes Martin , it looks very much like the top one 088421 but I make the part no. for this machine 096805. Do we agree these are different parts and not interchangeable with 096331 as was suggested above.
    Bryan
    #154771
    Dave_Conway
    Hmm, Bosch themselves don’t supersede 096805 to anything, Masterpart’s site does though to 096331 among various others.
    Wrong info I think 🙁
    #154772
    Bryan
    Yes Dave I was a bit worried you got that information from Masterpert website as some of their equivalents are slightly misleading IMO.
    No big deal , managed to snip and solder the brushes from 096331 into the original end cap but a damned expensive way to do it 🙄
    Cheers anyway and hope this helps for future reference.
    Bryan
    #154773
    gegsy
    Dave_Conway wrote:Hmm, Bosch themselves don’t supersede 096805 to anything, Masterpart’s site does though to 096331 among various others.
    Tradeplace has no part substitute Dave for 096805 so I would imagine that the part number 096805 is still valid 😕
    Bryan
    Just to finish off this saga , went back today with new end cap 096805 and all working fine and motor back to original spec.
    Pardon my ignorance can anyone explain how that tacho works , there is a magnet but no coil. That 3 legged device in the end cap is obviously pretty clever.
    Bryan
    #154775
    Bryan wrote:…managed to snip and solder the brushes from 096331 into the original end cap but a damned expensive way to do it 🙄
    Bryan
    Sounds like you have now purchased 2 end caps to change one set of brushes. Now that IS expensive. 😯
    #154776
    Bryan
    I originally quoted the customer for new end cap and that`s exactly what they now have. I now have a spare 096331 and I can solder the brushes back in without any problem.
    Extra work yes but at the end of the day I feel happy with it.
    Now , what about that tacho 🙂
    Bryan
