Re: Bosch WFT2800GB/13
rocker wrote:have no motor action , tested motor checks out ok…
Are you really sure the motor is OK? Have you checked out those brushes and stuff? The module is built like a brick bus shelter and on the very rare occasions they go AWOL it is the motor that causes it anyway!
Close visual on the module the only option if the motor does check out. The machine is 6 -8 yrs old now so the brushes should be pretty well shot I would have thought?
