Bosch WFT2800GB/13
  • #37468
    S1MON
    Bosch WFT2800GB/13
    Washer drier tripping over heat out on drier ducting found OC valve replaced this all seemed to work fine. Gone back today same agin but ive found the m/c with only fill and drain on setting 3 of the drying cycle.
    There is no valve or drain pump action on settings 1 and 2?
    Apart from the pcb anyhting else can cause this. It runs completely fine on setting 3
    #255223
    Re: Bosch WFT2800GB/13
    Doesn’t it have to get up to a pre-set temperature before the valve and the pump cut in?
    S1MON
    not sure on program 3 it comes on almost staright away and not at all on 1 and 2?
