Bosch WFT2800GB/13 Washer/Dryer No Heat
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFT2800GB/13 Washer/Dryer No Heat
  • #71312
    Latham63
    Dryer does not heat.Element,stat,fan ok.Live to one heater terminal + live reading on other terminal when connected.When heater wire is traced it goes to a pcb/coil on base of machine(this is linked to main pcb).Suspect a neutral problem in this area? Its as though heater is turned off.Heater timer control is another suspect? Any ideas?
    #380703
    Re: Bosch WFT2800GB/13 Washer/Dryer No Heat
    dont know specific machine layout but
    have you checked pcb for bad solder joint on relay if relay on main pcb
    have you checked relay ie is there a dc voltage on the relay coil
    Latham63
    Ntc connector nipped up,problem solved! Thanks.
