Bosch WFT2806 GB/13
  • #19454
    goosegreen
    Have a mate with the above w/m. The fault is: On spin it won’t ramp up to full speed seems to get to 800-1000 then stops, Also sometimes after the spin has finished the spin prog starts again. Have checked tacho, fill level, pressure chamber and pump filter. Wondering if it could be a module fault, but at Bosch prices I doubt it would be economical to repair.
    Would like to sort this one as he has offered to do my soffits and facias at £500 less than all previous quotes
    (Always looking for a deal) Goose
    #183165
    Re: Bosch WFT2806 GB/13
    I would tend to think it is the motor brush/end frame unit (Pt No 496876) not picking up the stator winding tapping for 1200rpm? Considering the age of the machine the brushes must be well low by now also?
    #183166
    goosegreen
    Thanks Martin, New brushes were fitted 3 Mths ago I wil call again and check that all the pins in the end plate are aligned.
    Goose
