Bosch WFT2806/GB13 FD8306 400287
Home Forums Trade Technical & Spare Parts Forums Trade Technical Enquiries Bosch WFT2806/GB13 FD8306 400287
  • #16027
    RocketMan
    Help 😥
    Initial complaint – no drum action but fills and empties ok.. new motor fitted … still fills and empties ok, but still no drum action…new power module fitted… fills .. erratic drum action (eg agitation is too fast…lasts for about 3-5 mins them stops)….
    when put onto spin…doesn’t ramp up to full spin….
    Any ideas??? ❓ ❓ ❓ ❓
    #167238
    gegsy
    Re: Bosch WFT2806/GB13 FD8306 400287
    Any lamps and number in display ??
    I would check loom wire from motor to module and earth leakage aswell.
    Bryan
    There seems to be 2 seperate PCB`S to make up this module , were both replaced ❓ . Part Number 155272 is described as Triac 😕 the other one is 295666.
    Bryan
    #167240
    gegsy
    Should still throw a fault up unless main module 295666 is faulty ❓
    RocketMan wrote:Help 😥
    was it the correct motor? some of those use a different Tacho set up which could cause those problems. Post the part number.
    #167242
    gegsy
    Only one motor listed Mark 140867 so should be interesting to see what they sent him.
