The dryer on this machine starts off ok gets hot then heater cuts out.
Stat still has continuity and has not tripped.
Tracing the wire from the heater down to the triac module on base plate.
Could this be the culprit?? No visual sign of damage.
Problem has been intermittent for some time.
The most common reason for this is the condenser and its bottom hose bunged with fluff. The NTC on the front heater box detects rapid rise in temp and shuts heater down. 😉
