bosch WFt8030 only spins on wool program
Home Forums Public Support Forums Help And Support Washing Machine Help Forum bosch WFt8030 only spins on wool program
  • #25332
    cwmbran
    Hello all, my Bosch machine has suddenly decided that it will only complete the wool cylce and no others , with all cycles apart from wool it goes through the washing process until it comes to draining then it stops? any ideas most welcome
    thanks
    #205459
    nomadPaul
    Re: bosch WFt8030 only spins on wool program
    you will need to give the full model number before any advice can be given. should be on a sticker on the inside of the door
    #205460
    gegsy
    Check that you don’t have the “Rinse Hold/Anti crease” button activated 😀
