HI
Problem is that 2 light flash and user book says water inlet blocked or low pressure. Works fine on wash but stops on rinse probably because wash fills hot aswell. Although cold water is quite slow I would have thought it would wait longer than 4 minutes to time out.
Pressure chamber is clean and I have checked everything else so think a new cold valve is needed.
Unless anyone can point me in a different direction.
typical Friday.
Cheers
