My machine suddenly started to make a racket during spin cycle, it sounded as if there was something stuck in between the drum and the outer drum, I got a torch and tried to see through the holes in the inner drum but couldnt see anything.
I removed what I can think of as either a thermostat or a pressure sensor in the back of the outer drum and looked for something in there but I could see nothing, but I noticed that when I spun the drive manually the drum did not look as if it was round ie it did not run true. The bearing has about 1 mm of play and I suspect the bearings have gone, if so how would I replace it? is is worth it and what would I need tools and parts.
