Hi, I have a bosch 1200 exxcell wfx2467 washing machine.It blew the mcb on the ring main and now all that happens when switched on is the three red LED lights flash, there is no display lit.
I changed the drain pump and checked for blockage in the waste pipe. It made no difference. Has anybody any suggestions? Thanks Keith.
Re: bosch wfx2467 exxcel 1200 all 3 red lights flash
Hi Martin
The machine tripped the mcb whilst on the drain cycle, I have a main motor so I will change that. I presume it was in intermittent fault as it doe’s not trip the mcb now when switched on.
Thanks Keith
Throwing parts at it rarely solves an issue of this type. You’re far better off solving an electrical insulation problem by firstly locating the fault with a test meter. 😉
